Author: Subject: duratec help
goaty
posted on 12/10/09 at 08:04 PM Reply With Quote
duratec help
hi,
striped my duratec down this eve ready to take to scholar for all the work but i got everything out bar the Crank Cradle, the bolts (15mm) are either very tight or i am missing something.
I only tried a couple as needed to go but i managed to crack them, then they didn't want to move.
Didn't want to hang off them until i ask someone if it is safe to.....
Getting it apart was fun, only took 1.5 hours to be completely bare on the stabnd and bench, all looking good iside too
austin man
posted on 12/10/09 at 08:15 PM Reply With Quote
did you check the manual for the torque settings ?? if so use a torque wrench set to 5lb / 10lb above
