Author: Subject: deoilcoolering an XE
cd.thomson
posted on 16/10/09 at 04:47 PM Reply With Quote
anybody done it?
Getting the pipe work sensible and fitting it is becoming a pain. I don't imagine theres much need for one in the UK with our airtemps either!
different filter needed?
Craig
tomgregory2000
posted on 16/10/09 at 04:51 PM Reply With Quote
My xe never ran with one and no problems
cd.thomson
posted on 16/10/09 at 04:55 PM Reply With Quote
how did you get rid of it tom?
just have a blind pipe off the sandwich plate, or remove it and fit a filter witha shorter screw in seem to be the two options
Craig
westy turbo
posted on 16/10/09 at 05:11 PM Reply With Quote
why take it out?
cd.thomson
posted on 16/10/09 at 05:29 PM Reply With Quote
Because I'm having a bit of a saga with the guys who supplied my flexible pipe to fit it. they came slightly wrong so wasnt usable. There are no other places nearby to sort it.
Also mounting it is tricky, having to use U-clamps round some cylindrical chassis members seems a bit of a bodge.
Its something thats causing me hassle I dont need, costing an excessive amount of cash (probably end up £100 for the pipes after I've slogged it out with this hydraulics place).
The easiest solution would just be to buy a £5 replacement filter and be done with it.
Craig
cd.thomson
posted on 16/10/09 at 05:32 PM Reply With Quote
sorry if that sounded ranty, having a bad week.
For future reference I believe I have found the solution:
The sandwich plate must be removed and the long stud removed.
This should be replaced with a short stud from the 8v engines (V0090322488 from main dealer) then I believe the original filter can be refitted.
Craig
loggyboy
posted on 16/10/09 at 05:43 PM Reply With Quote
My Xe didnt have one from factory (Came from Cav SRi not GSi).
IIRC u just need to remove filter, sandwich plate and the little extension peice and replace it with a shorter one and pop the filter back on.
Edit - should write my replys quicker!
[Edited on 16/10/09 by loggyboy]
cd.thomson
posted on 16/10/09 at 06:12 PM Reply With Quote
actually the old man has just suggested putting two bolts into the takeoffs on the sandwich plate. Already got the bolts, so its free!
Durrr why didnt i think of that.. Knew I had him around for a reason
Craig
tul214
posted on 16/10/09 at 07:02 PM Reply With Quote
What are you doing with the oil cooler and pipes?
Any pics?
1.6 Raw Super6 sold
turbodisplay
posted on 16/10/09 at 07:26 PM Reply With Quote
External oil cooler? I would strongly recommend keeping it. My parents sri astra 1.8 8v had a collant leak resulting in no collant in the system. If it didn`t have an oil cooler it would have seized for sure, doing 90 - 100 leptons on the motorway.
Must have been empty for at least half an hour.
How much is the hassel of a new engine if you have a coolant leak, fan fail etc.
Darren
