55ant
| posted on 17/10/09 at 03:45 PM |
rounded sump bolt
Like above, just been out to drain the oil and the plug is pretty rounded, even the mole grips wont get it,
anyone else had this problem, looks like its a magnetic bolt, also it may have been knocked as the sump area looks a little indented
regards
ant
away from cars, now cycling and building TT bikes
Steve Hignett
| posted on 17/10/09 at 03:47 PM |
Weld a nut or bolt to it and just undo, then grind off.
55ant
| posted on 17/10/09 at 04:01 PM |
unfortunately im at my dads and have no welding stuff! : (
owelly
| posted on 17/10/09 at 04:38 PM |
Stilsens?
http://www.ppcmag.co.uk
| posted on 17/10/09 at 04:43 PM |
yup stillsons
or just get a pump to suck the oil out via the dip stick hole --- local yacht chandlers will stock them at a very good price.
55ant
| posted on 17/10/09 at 04:55 PM |
cheers chaps, gunna give it another go in the morning, its beer o'clock now the f1's on.
turbodisplay
| posted on 17/10/09 at 06:04 PM |
From machine mart a bolt extractor made by irwin. SOOOOO good, got a reverse flute inside. Yet to find something it has not been able to remove.
Darren
[Edited on 17/10/09 by turbodisplay]
owelly
| posted on 17/10/09 at 06:35 PM |
I saw a set of those IRWIN nut/stud removers at Homebase today. £19 IIRC fro the set.
hobbsy
| posted on 17/10/09 at 07:13 PM |
Another vote for the Irwin extractors - I have both the normal and the expansion set - I just wish they did some even smaller ones sometimes...
madteg
| posted on 17/10/09 at 07:48 PM |
Whack a smaller socket on it ( twelve sided one maybe a imperial one say 1/2" for a 13mm nut or even a 12mm).
| posted on 17/10/09 at 08:00 PM |
id vote stilsons, they can grip a round pipe, never mind deformed nuts.
| posted on 17/10/09 at 08:03 PM |
When you have rounded it off completely with the stilsons then weld on a nut . Works every time
madteg
| posted on 17/10/09 at 08:08 PM |
There's always the good old hammer and chisel method.
skodaman
| posted on 18/10/09 at 01:50 AM |
There are special sockets for just this eventuality. When I did this on a zetec sump a mate borrowed one from another mate who owned a garage so
don't know where u'd buy one from but they do exist and work well. Second to that easiest thing is to weld a ring spanner on and use a
bar to get it off.
Skodaman
