madteg
| posted on 19/10/09 at 08:47 PM |
Turbo problem
On rolling road my car spikes, how can i stop it because i am loosing so much tracktion. By spike i mean it comes on boost lovely but then it goes
from about 220 bhp straight up tp 300ish, which means loads of wheel spin. I want to stop it as its loosing me time on track.
zilspeed
| posted on 19/10/09 at 09:01 PM |
What sort of boost control do you use ?
tomgregory2000
| posted on 19/10/09 at 09:03 PM |
what you want is an APEXI AVCR boost controller, you can set it to give you whatever boost you want at what rpm and in which gear you want.
Its a clever bit of kit but costs new abot £500 but you can pick them up second hand on the sxoc forum.
My sr20det has one with it which is good but it does take some setting up
madteg
| posted on 19/10/09 at 09:05 PM |
Not running any boost control at the moment apart from the wastegate.
tomgregory2000
| posted on 19/10/09 at 09:12 PM |
Well there be your problem, like i say get a propper controller but they do cost the money.
When is the wankel going to be fitted?
zilspeed
| posted on 19/10/09 at 09:17 PM |
Indeed.
When you think that the modern boost controllers will use the throttle position as one of the parameters considered when allowing the relevant level
of boost, your problem could be dealt with.
locoR1
| posted on 19/10/09 at 09:22 PM |
That's exactly how mine was the boost came on so strong it just broke traction! it was fun for a while but you soon get fed-up with going
sideways when you didn't intend it
Fitted an e-boost 2 controller to mine it can do boost by gear on some production cars but on mine i use the boost by rpm function mapping the boost
throughout the rev range transformed the way the car drives knocked a second of my 0 to 60 time.
Just remembered it has an overboost setting as well so keeps your engine nice and safe!
Check out my CB500T Cafe Racer build diary
INDY BIRD
| posted on 19/10/09 at 09:23 PM |
could also eun e boost contoller again controls boost 6 settings in every gear,
this should help you but again is ££££ but not quite as expensive as the others
turbodisplay
| posted on 19/10/09 at 09:41 PM |
Is your wastegate big enough? If it is too small it could be chokieing up and so the exhaust gases can only go via the turbine.
Darren
hobbsy
| posted on 19/10/09 at 11:11 PM |
Just a normal more basic EBC could be picked up on eBay for under £100 second hand. Even a "dawes device" mechanical boost controller
could be better than nothing.
Also what Darren said could be a factor - you can port the wastegate if you're using a turbo with an internal wastegate. Or shut that one off
and run an external wastegate. Then you can run a screamer pipe to really scare pedestrians They sound like a jet taking off when you start
making full boost
Ivan
| posted on 20/10/09 at 06:17 AM |
Read part 1 & 2 of this - it might help - there are many articles in here about practical locost solutions to boost control
http://autospeed.com/cms/A_111348/article.html
turbodisplay
| posted on 20/10/09 at 06:45 AM |
What efi are you using, megasquirt can be setup for boost control, using the extre code.
Darren
westy turbo
| posted on 20/10/09 at 09:15 AM |
At first whats the max boost you getting?
| posted on 20/10/09 at 05:37 PM |
The Dawes/PRV style boost controllers make the boost rise even more violent than without since they keep the wastegate fully closed until a preset
threshold has been reached. By itself the wastegate will gradually open more as boost pressure increases, which gives a more gentle ramp.
Note that any type of boost controller, mechanical or electronic can only raise the boost above the level that the wastegate naturally opens. If the
OP is already getting the desired boost purely under wastegate control, he'll need a lower pressure actuator to be able to control it.
[Edited on 20/10/09 by MikeRJ]
Antnicuk
| posted on 20/10/09 at 05:39 PM |
i would see what pressure actuator you have, then find a lower pressure one, then you can use a simple electronic boost controller with a gain
setting to make the boost come in smoother and more gradual.
Tom Gregory 2000 You can not make a car run less boost than the actuator or wastage setting with any boost controller, you can only increase boost.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
westy turbo
| posted on 20/10/09 at 06:07 PM |
as said above apexi avcr is the best...i do have it and you can set each gear with different boost settings 1,2 nly wastgate boost and then from 3rd
and on give it some
Frosty
| posted on 20/10/09 at 11:38 PM |
I totally agree. The best boost controller in the world will not be able to help here. They can only increase boost.
Find the pressure of your wastegate actuator, and then fit one which opens at a lower pressure. You can then add more boost to your desired level with
a boost controller of some description after this point.
