marcjagman
| posted on 21/10/09 at 07:22 PM |
Pinto 205 block
Okay so this will probably seem a stupid question to many, but I'm going to ask, what is so special about the 205 block? I vaguely remember
reading something somewhere that they were used as the base for the cosworth engine. So what's the deal with them?
omega0684
| posted on 21/10/09 at 07:30 PM |
its stronger than the 200 block and has extra webbing towards the back of the block, thats about it
marcjagman
| posted on 21/10/09 at 07:34 PM |
Cheers, does anyone know if a cosworth head fits?
lotusmadandy
| posted on 21/10/09 at 07:36 PM |
It also has an oil drain with a blanking
plug ,on the exhast side for the turbo.
It's just below the coolant drain plug.
Cosworth head fits but you need to
change the pistons and i am sure you need to change the waterpump
jacko
| posted on 21/10/09 at 08:35 PM |
The 200 block is stronger then the 205 it was the 2l older block that was not as good
The 200 block was used in the 4 wheel drive cosworth escorts
omega0684
| posted on 21/10/09 at 09:13 PM |
^^^ sorry thats what i meant, mind you wasn't the pre 205 block marked with a 20 on the sid eit indicate it was 2ltr?
garyo
| posted on 21/10/09 at 09:30 PM |
The YB head will fit on the block. You'll need to fit a wider crank and aux shaft cam belt pulley to cope with the wider cam belt, and deal with
the compression ratio problem else you'll end up with about 9:1.
I used a 2.1 bottom end, which gave me 10:1 compression.
The standard cams on a YB are useless too, as they designed for turbo use so have very little duration/overlap.
If you're using it normally aspirated then you'll also need to get a custom exhaust manifold and ideally do some porting work on the inlet
side to open the inlet tracts out.
I don't remember having any water pump issues.
Gary
garyo
| posted on 22/10/09 at 07:34 AM |
I was thinking about this last night. I did this conversion around 8 years ago, and even then it was a slightly dubious decision given what else was
available - a VX on twin 40's etc.
I think I gave too much weight to the fact that I wouldn't need to swap over the bonnet and exhaust if I stuck with the pinto/YB inlet/exhaust
alignment.
A 2.1 bottom end on Jenvey 40s, ported head, and 290 cams made 197bhp and 160 lb/ft for me, at a sensible ~7000 rpm.
It was a lovely looking setup though... almost worth it for the rocker cover alone :-)
Gary
