Author: Subject: Alternator pulley
norfolkluego
posted on 21/10/09 at 07:54 PM Reply With Quote
Alternator pulley
(If the spinney thing on the front is called a pulley)
I was hoping to reuse the alternator from the Crossflow on the Zetec that's about to go in but the pulley is a narrow deep V shape and the Zetec belt wont fit, can they be changed (the pulley that is)
posted on 21/10/09 at 07:59 PM Reply With Quote
Yep, should just bolt straight on..
whitestu
posted on 21/10/09 at 08:15 PM Reply With Quote
The large nut holding the pulley on will be tight. I needed an impact gun to get mine off.
Stu
James
posted on 22/10/09 at 10:58 AM Reply With Quote
Will a Zetec pulley fit as a straight swap?
If not, Flak Monkey is your man for making custom pulleys!
James
flak monkey
posted on 22/10/09 at 11:12 AM Reply With Quote
You might find they have different shaft sizes, but nearly all modernish alternators are either 14mm or 15mm shafts. Not sure what the crossflow one would be though.
Sera
http://www.motosera.com
