Author: Subject: Exhaust discolouration
speedyxjs
posted on 22/10/09 at 08:33 PM Reply With Quote
Just wanted to check to make sure this is normal.
After my first long engine run, the exhaust has the normal blueish tint, as they normally do. The thing i am a bit concerned about is the fact that it is discoloured right up to the silencer.
Is this ok as i have never seen this much exhaust 'blued'?
austin man
posted on 22/10/09 at 08:35 PM Reply With Quote
would suggest a lot of heat, have you noted any overheating problems ?? is it running ok ?? if both the previous are ok I wouldnt worry
speedyxjs
posted on 22/10/09 at 08:39 PM Reply With Quote
It had an air leak but not sure if that would increase the temperature. A small section was covered in exhaust wrap to protect the brake reservoir and it was idling at, i would guess, around 3-4000 rpm as it wouldn't idle (hopefully caused by the air leak).
iank
posted on 22/10/09 at 08:43 PM Reply With Quote
It will get much hotter if it's running lean due to the air leak.
Be careful you can destroy an engine if it's very lean.
[Edited on 22/10/09 by iank]
Anonymous
speedyxjs
posted on 22/10/09 at 08:46 PM Reply With Quote
Be careful of you can destroy an engine if it's very lean.
Well that would probably explain it then
The air leak should be sorted now but i need to put some more oil in before i can test it and i cant afford the oil atm
prawnabie
posted on 22/10/09 at 08:49 PM Reply With Quote
What oil are you after speedy?
speedyxjs
posted on 22/10/09 at 08:51 PM Reply With Quote
10w 40
twybrow
posted on 22/10/09 at 08:54 PM Reply With Quote
You have to run very lean (AFR 17+), and normally under load to really do damage don't you? If your zorst is new, then I wouldn't worry - I think it looks much better than shiny stainless!
mark chandler
posted on 22/10/09 at 09:30 PM Reply With Quote
If you run a cars engine with it parked up then the exhaust will get very hot as nothing blowing around to cool it off.
So 5 minutes @ 4000rpm, no load would start to make the thing red hot along its entire length
A1
posted on 23/10/09 at 10:37 AM Reply With Quote
when my engine was running very lean it was glowing after a minute or so of running, but when i was at the sva they were running it for about 20 mins and it was fine, no redness at all
