Author: Subject: Another Duratec Q
posted on 23/10/09 at 01:28 PM Reply With Quote
Another Duratec Q
What's this...
Doofus
posted on 23/10/09 at 01:30 PM Reply With Quote
Crank case breather
posted on 23/10/09 at 01:43 PM Reply With Quote
Doh!
Cheers!
Doofus
posted on 23/10/09 at 01:50 PM Reply With Quote
I blocked that off on my old engine and just ran a filter on the rocker cover.
Never used a drop of oil
I suspect the best solution is to run them both into a catch tank.
flak monkey
posted on 23/10/09 at 02:00 PM Reply With Quote
Yep block breather, as doofus says run both to a catch tank.
If dry sumping you need to block the block breather off.
Sera
http://www.motosera.com
posted on 23/10/09 at 02:12 PM Reply With Quote
Cheers... been looking at your Duratec thread Flak - there's quite a few differences between my engine and yours (sump shape, EGR port location, PS pump location, etc.)
Mine came from an 06 ST150 - what car was yours in?
Stuart_B
posted on 23/10/09 at 03:20 PM Reply With Quote
hi scootz, i just saw the picture and new you had a newer engine than mine as you beather pipe outlet is bigger.
my duratec came form a 2001 mondeo.
stuart
posted on 23/10/09 at 03:39 PM Reply With Quote
Phew... I was starting to think I'd bought a Duratec badged Zetec!
flak monkey
posted on 23/10/09 at 03:44 PM Reply With Quote
Yeah st150 and mondeo engines are slightly different.
If you have the st150 engine you should also have the solid flywheel which will take a 220mm zetec/cvh clutch
Sera
posted on 23/10/09 at 03:49 PM Reply With Quote
What's the benefit of changing out the original clutch for the Zetec / CVH one?
flak monkey
posted on 23/10/09 at 03:56 PM Reply With Quote
Splines are different IIRC
The OE one will be a 20mmx17 spline i should think as this is what most of the current ford boxes are.
The T9 is a 1" x 23 spline input shaft so needs the appropriate friction plate.
If the pressure plate is good then you only need to change the friction plate.
Sera
posted on 23/10/09 at 04:08 PM Reply With Quote
Perfecto!
Thanks!
