Author: Subject: CLUTCH RELEASE/THRUST BEARING
big-vee-twin
posted on 1/11/09 at 08:57 AM Reply With Quote
I'm going to be mating a type 9 to a Zetec engine.
I want to replace the thrust bearing before I do this, which is the best to use the standard Sierra one or I understand the Capri one may be a better option.
Also how much play is acceptable on the input shaft just want to check.
http://www.triangleltd.com
big_wasa
posted on 1/11/09 at 09:21 AM Reply With Quote
You want a longer bearing such as the QH cct133 there was a guy selling them on ebay but I can not find it at the mo'
The standard bearing on a Fwd cover plate will reduce clutch travell by about 20mm
lotusmadandy
posted on 1/11/09 at 09:22 AM Reply With Quote
CT 133
Off a capri is longer than the sierra one,
if dont you will run out of clutch travel.
big-vee-twin
posted on 1/11/09 at 11:18 AM Reply With Quote
Thank you
