Bumble
| posted on 3/11/09 at 02:10 PM |
Which Starter Motor??
I have a 1.8 Silvertop (97) from a Ford Escort. It has standard 1800 Flywheel, 220mm Mondeo Clutch Kit with CCT 133 Thrust Bearing mounting to type 9
box. Can soemone tell me which starter I need as I've seen several different ones mentioned on here?? Confused..........
bbwales
| posted on 3/11/09 at 02:46 PM |
hi,
I have used a startermotor out of a Ford 2.0l DOHC and I believe a CVH 1.8 Starter will also fit.
Regards
Bob
lotusmadandy
| posted on 3/11/09 at 03:23 PM |
Pinto starter fit as well with a 14mm
spacer between the bell housing and
starter.
I know because i have a pinto motor
on my silvertop.
UncleFista
| posted on 3/11/09 at 04:38 PM |
Sierra DOHC starter used here too
Tony Bond / UncleFista
austin man
| posted on 3/11/09 at 06:27 PM |
2l dohc granada fits as well as 2 dohc sierra as well as the 1.8 cvh sierra. The sump will require modifying on the starter motor side as the starter
fouls it
