speedyxjs
| posted on 3/11/09 at 05:17 PM |
Well its about time i hear you say
After Mark Chandlers comment the other day about Jag engines being sensitive to air leaks, i decided to pull the inlet apart and inspect
everything.
Two minutes in, i found a small screw missing for the idle valve at the bottom of the manifold.
Put a new one in and put it all back together and she now idles nice and low and smooth
Thanks to Mark and everyone who helped with this problem
Breaker
| posted on 3/11/09 at 05:22 PM |
Don't you wonder where the missing screw might be ?
zilspeed
| posted on 3/11/09 at 05:29 PM |
My Golf had an ever so slightly leaky vacuum hose from the inlet manifold to the fuel regulator.
It ran pretty much fine but stumbled occasionally and tickover was always a bit lumpy.
Of course the ECU learnt over time to add a bit of fule to correct for the air, but it wasn't exactly consistent so no amount of self learning
would sort it.
Since I fixed the hose a couple of days back, it idles better than ever and generally runs nicer and smoother.
Air leaks screw everything up.
speedyxjs
| posted on 3/11/09 at 05:30 PM |
I dont know where it is. I had to find one in my odds and sods drawer
Breaker
| posted on 3/11/09 at 05:43 PM |
OK, so you are sure it is not lost in the cilinder head somewhere ...
| posted on 3/11/09 at 05:48 PM |
Noooooooooooooo!
MikeR
| posted on 3/11/09 at 06:06 PM |
naah, its not in the cylinder head yet ............
give it another week in the inlet before it makes its way into the cylinder head
speedyxjs
| posted on 3/11/09 at 06:32 PM |
Naah, it wont be in there
