franky
| posted on 12/11/09 at 07:36 PM |
Hayabusa Questions
A few questions....
have most people removed the pair system?
Does anyone run a remote oil filter setup, if so what size sandwich plate did you use?
Where have you mounted oil pressure/temp sensors?
any info that you think will be useful?
Jon Ison
| posted on 12/11/09 at 07:52 PM |
1) Yes.
2) I don't.
3) I pick up oil temp from sump, oil pressure from the pipe leading to my accusump which is plumbed into the main oil gallery bottom front left of
engine when installed in car.
Frosty
| posted on 13/11/09 at 02:36 PM |
Definitely remove the pair valve. The rubber vacuum pipes come off when you hit the limiter and make you think you have an oil pressure problem
because of the sound they make. Very scary and annoying.
Oil pressure sensors should be remote mounted from the engine or the vibration kills them.
I think just using the factory installed oil pressure switch is just as good though. Hook it up to an LED to display if there is an oil pressure
fault.
franky
| posted on 13/11/09 at 03:11 PM |
I've got a stack pro control oil pressure gauge and with the sensor that comes with it vibration doesn't harm it.
Think i'm going to run a remote filter system to give myself more space.
motorcycle_mayhem
| posted on 13/11/09 at 04:40 PM |
Yes. Invert engine, tap a thread, screw in a plug... or use nice covers, homemade or there are some bling ones out there.
Yes, Mocal plate and a 20mm mushroom (Westfield).
Racetech sensor hanging out of a drilled and taped gallery plug.
franky
| posted on 13/11/09 at 05:30 PM |
HI,
what do you mean by a 20mm mushroom?
