rich201283
| posted on 10/4/04 at 08:32 AM |
ground clearence
Whats the lowest ground clearance between the sump and the groung you can have as ive only got 3 inch clearence do you think tis is enough?
| posted on 10/4/04 at 09:49 AM |
Not for road use --- aim for 4 inch / 100mm minimum
Watch particularly the clearance under the bellhousing.
[Edited on 10/4/04 by britishtrident]
Tigger
| posted on 10/4/04 at 09:59 AM |
Can't you adjust your ride height?
If not and you do decide to use such a low clearance, I would suggest you fit a skid pan.
This will deflect any obstructions saving your sump/engine from terminal damage.
Very easy to make and fit.
Tigger
Mark Allanson
| posted on 10/4/04 at 11:54 AM |
Have you done a sump chop?, the bottom of my chassis is 5" above the ground and my chopped sump is 1" below the chassis
