Author: Subject: Duratec rpm pick up
MK9R
posted on 16/11/09 at 07:32 AM Reply With Quote
Duratec rpm pick up
Where is the best/easiest place to pick up the rpm single for a duratec? Its for an input into an ECU, so needs to be clean, if you know what I mean
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
flak monkey
posted on 16/11/09 at 07:55 AM Reply With Quote
What ignition system are you using? If using an ecu it should pick it up off the crank sensor anyway as its using this to determine the ignition events anyway.
Otherwise EDIS has an RPM output pin IIRC, but I cannot remember which pin it is.
Sera
http://www.motosera.com
MK9R
posted on 16/11/09 at 07:57 AM Reply With Quote
Its the ECU for the LPG system i amd fitting to my 1.8 2007 mondeo. Instructions say pick it up from back of rev counter or negative side of the coil.
Cheers Austen
RGB car number 9
www.trackace.co.uk
flak monkey
posted on 16/11/09 at 08:49 AM Reply With Quote
Ah, righto.
There should be an RPM signal from the ECU to the tacho which will be a 12v square wave signal I should think.
You can't pick it up from the coil as it runs wasted spark.
Probably best having a look at the wiring diagrams in the Haynes book.
Sera
MK9R
posted on 16/11/09 at 08:56 AM Reply With Quote
Ah, righto.
cheers, i suppose that would come in handy as i've got to break into the lambda signal wire and injector loom aswell
anyone got an electronic copy????
Cheers Austen
RGB car number 9
www.trackace.co.uk
