Author: Subject: Dcoe or bike carbs
carlknight1982
posted on 16/11/09 at 03:42 PM Reply With Quote
Dcoe or bike carbs
Ok due to my change of plans i need to figure out my fueling.
I have a pair of 40 DCOE webbers but need to get a pinto manifold for them.
or do i ditch the dcoe's and go for bike carbs?
Logic will get you from a A to B
Imagination will take you everywhere.
RAYLEE29
posted on 16/11/09 at 03:54 PM Reply With Quote
Its a personal preference thing really and it depends on what you have if you just need a manifold you can pick them up for a reasonable sum but if you need everything then selling the webers and going bike carb might work out cheaper
my bike carb set up owes me about £60 so far without filters
I paid £48 for the carbs delivered and £15 for the silicon hoses and my manifold has just cost my time
if its not about cost then I beleive bike carbs offer better driveability but i dont have proof as my car is nowhere near being finished
Ray
jacko
posted on 16/11/09 at 04:10 PM Reply With Quote
AS above but dcoe do need setting up quite often and bike carbs set them up once and leave alone
t16turbotone
posted on 16/11/09 at 04:15 PM Reply With Quote
USED Pinto twin DCOE manifold on ebay
item number 280424285035
might get it cheap!
RichardK
posted on 16/11/09 at 04:26 PM Reply With Quote
Of course personal choice will prevail but if it was me I would go bike carbs, if I had the choice of the two, if they'd been 45's it would have been a tougher choice.
Rich
Gallery updated 11/01/2011
lotusmadandy
posted on 16/11/09 at 04:29 PM Reply With Quote
Bike carbs for me everytime.It
is of course my personal choice,some
prefer webbers.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 16/11/09 at 04:36 PM Reply With Quote
bike carbs for me, power all the way through the rev range and once set up they are a pain free operation
cliftyhanger
posted on 16/11/09 at 05:21 PM Reply With Quote
Nothing wrong with webers! After all they were used on many many production cars, something bike carbs have never been!
Once set up with the correct jets etc then they will stay in tune too. I do not understand why people think they are a problem?
Both need a rolling road to set up properly, I guess you could just slap the "advised" jets in webers and it would be OK, as much as drilling jets on bike carbs. But to get either spot on will cost.
Not sure about using silicone either, it breaks up when used with petrol! needs a special variety (fluro something IIRC)
mookaloid
posted on 16/11/09 at 05:55 PM Reply With Quote
Why not try the webers with the cheap manifold. then if you don't like them it's only cost you for the manifold as you already have the carbs.
Unless you have a tuned engine, the 40's will be fine, giving good mid range power but only losing out at the top end to 45's if you are going for say 150BHP+ out of the pinto.
The webers will sound great and suck small children off the pavement as you roar past!
Go for Bike carbs if the webers are worn or knackered. they are impossible to set up if the shafts are bent or there are blocked jets etc.
DRC INDY 7
posted on 16/11/09 at 06:12 PM Reply With Quote
Bike carbs the next best thing to fuel injection based on the su carb
Webers have had there day and should be left there i have delt with many over the years new and old set up on rolling roads etc all being a lot of trouble
Puddle Dodgers Club
cliftyhanger
posted on 16/11/09 at 06:15 PM Reply With Quote
As a thought, have you checked what chokes, jets etc are fitted to the webers, and that everything moves as it should?
There is plenty of advice out there, weber jets can be drilled to enlarge, but tubes can't (unless you REALLY know what you are doing!!) Changing stuff on webers can get eye-watering....but once done properly they can be VERY good.
Please also note, the production cars that used weber DCOE or the downdraft versions were all rather tasty!
flak monkey
posted on 16/11/09 at 08:29 PM Reply With Quote
DCOE's everytime. If you can live with the fuel economy (20mpg) then go for the Webers. Many more people will rolling road tune webers than they will bike carbs.
Had a set on the pinto and it was brilliant. I then moved on to fuel injection which was even better!
Sera
http://www.motosera.com
Steve G
posted on 16/11/09 at 09:07 PM Reply With Quote
bike carbs for me every time. DCOE's or DHLA's never seem to stay in tune for long whereas bike carbs are sooooooo much simpler (less to go wrong / adjust), hold tune better and are smoother generally where the DCOE's can suffer flat spots around the progression point between idle and main jets unless very well tuned all the time.
whitestu
posted on 16/11/09 at 09:09 PM Reply With Quote
I've had several Alfas with Webbers and Dell'ortos on and they rarely went out of tune [Dell'ortos worked better]. They weren't 'DCOEs but work in the same way.
I have bike carbs now but that is just for cost.
Stu
flak monkey
posted on 16/11/09 at 09:50 PM Reply With Quote
Wbers and Dellortos cannot go out of tune. The jets are fixed.
All that can happen is they go out of balance, but that shouldnt happen either as long as the link is in good condition.
Sera
austin man
posted on 16/11/09 at 10:41 PM Reply With Quote
I returned 26 mpg on twin 40's driven hard on a 1,8 zetec
prawnabie
posted on 16/11/09 at 11:00 PM Reply With Quote
I return with burst eardrums when I drive mine hard!!
I considered this a few weeks back.... I concluded that god would strike me down in flames if he ever found anything off a bike attached to my car. I would repent at the soonest opportunity!
Dingz
posted on 16/11/09 at 11:14 PM Reply With Quote
If you have the webbers jetted (approx)for your motor and the linkages then I suggest sticking with them, but I like the bike carbs on my pinto, very smooth.
went on and on.
