semi42
| posted on 13/8/02 at 08:35 PM |
Pinto Engine Mountings
According to the lolocost parts list,When fitting the pinto in the chassis, the Sierra engine brackets are swapped over and the original rubber mounts
used . These are bolted to 2 inch high lolocost brackets welded or bolted to the chassis. the question is...will the case be the same with Cortina
mk4/5 engine mounts?
theconrodkid
| posted on 13/8/02 at 08:57 PM |
Seirra ones are alloy castings and come out quite a way,from memory the tina ones are steel and a fair bit shorter
