Author: Subject: Pinto q's
carlknight1982
posted on 19/11/09 at 07:12 PM Reply With Quote
Pinto q's
Are the heads from the 1.8 pinto's interchagable with the 2l?
also what other parts are, obv pistons rods , crank and block arent, what about flywheel etc?
Logic will get you from a A to B
Imagination will take you everywhere.
snapper
posted on 19/11/09 at 07:15 PM Reply With Quote
I belive that they are, certainly the 1.6 can go on a 2.0L however your valves will be smaller and a different length and the combustion chamber will be smaller, which may help with extra compression ratio but you must now measure everything to make sure.
I eat to survive
I drink to forget
snapper
posted on 19/11/09 at 07:20 PM Reply With Quote
same stroke as the 2.0L so assume same crank, rods are the same, flywheel, don't know
I eat to survive
I drink to forget
DRC INDY 7
posted on 19/11/09 at 09:39 PM Reply With Quote
The later version 1600 is the same stroke as the 1800 and 2000cc pinto
165 185 205 block castings
The rods a crankshafts will fit all 3
Flywheels 215 mm clutch from the later 1600 is the same for the 1800 and 2000cc
earlier 1600 pinto had a 190mm clutch the flywheel will fit the later engines just needing the smaller clutch
[Edited on 11/19/2009 by DRC INDY 7]
Puddle Dodgers Club
bigpig
posted on 20/11/09 at 08:58 AM Reply With Quote
I was told they are, but the 1.8 combustion area may be slightly smaller.
I've still got a spare 2.0 head in the garage that we forgot to load in your car after the hernia inducing engine lifting
You are welcome to come and pick it up this weekend if you still want to, along with the set of seat runners we forgot to drop in too & a strip of grip tape
