lotusmadandy
| posted on 20/11/09 at 09:07 PM |
Zetec sump depth
This is one for all you peep's with a zetec in an Indy.The 1600 Escort sump and pipe
arrived today,big thanks to The Conrodkid. It is a little
deeper than i thought it would be,so am a tad concerned about ground clearance.
Has anyone had ground clearance problems using this sump and how far does it protrude below the chassis.
Many thanks,
austin man
| posted on 20/11/09 at 09:15 PM |
Mine is level with the bottom of the bell housing. Has it shortened by Martin Keenan. the mondeo sump also needs modifying at the side where the
starter fits as the sump fouls the starter
lotusmadandy
| posted on 20/11/09 at 09:32 PM |
I dont suppose you could measure
from the face of the block to the bottom of the sump?
Mine is 170mm and i dont have a bellhousing to offer up to the block.
Thanks,
paulf
| posted on 20/11/09 at 09:41 PM |
I cut mine down and level with the bell housing and had to remove about 20mm so depth ended up at 150mm.
Paul.
Thanks,
