tomgregory2000
| posted on 21/11/09 at 10:28 AM |
Intercooler size question?
Ive been looking but i cant find what im after.
What i want is some info on what size of core i need to cope with the amount of power/boost pressue/airflow i am looking to produce.
Does anybody know of anything?
liam.mccaffrey
| posted on 21/11/09 at 11:04 AM |
Corky Bells pressure charging books are very good and cover this.
[Edited on 21/11/09 by liam.mccaffrey]
Build Blog
Build Photo Album
t16turbotone
| posted on 21/11/09 at 11:17 AM |
hi, i seem to remember that there is a section in the MS mega manual that overs this
http://www.megamanual.com/v22manual/mturbo.htm
| posted on 21/11/09 at 01:00 PM |
Graham A. Bell's book (forced induction tuning) is also useful here.
Basically though- go for the biggest you can but you need to try and reduce pressure loss to a minimum so you don't want long tubes, you really
want lots of short tubes (to an extent)...
Antnicuk
| posted on 21/11/09 at 09:51 PM |
you will generally be restricted on space so just get the biggest you can. Make the pipe work as direct as possible, every 90 degree bend can add 1
psi pressure drop in the system.
What power and boost are you looking at running?
A stock sierra 4x4 intercooler is very good and easy to fit and easily copes with over 300 and 25 psi boost. They are getting a bit old now
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
bimbleuk
| posted on 21/11/09 at 11:05 PM |
I used and so do OMEX/RAW in there kits the standard MR2 turbo intercooler. Big enough to flow at least 270BHP which was what my engine was pruducing.
Hangs in front of a polo rad easily and costs about £35 quid from Fensport etc.
westy turbo
| posted on 22/11/09 at 07:25 AM |
Not so locost,but thats the one i bought
http://www.radtec.co.uk/index.php?p0=detail&id=445&cpid=39&cid=127&partNo=RWTC
Ivan
| posted on 22/11/09 at 07:34 AM |
This is worth reading and might help in the selection process
http://autospeed.com/cms/A_1931/article.html
t16turbotone
| posted on 22/11/09 at 07:58 AM |
this is what i fitted........Ebay item 350280616870, just £60. All Alloy
westy turbo
| posted on 22/11/09 at 08:32 AM |
forgot to mention is rated for 400hp
