Author: Subject: clutch problems
t16turbotone
posted on 22/11/09 at 11:37 AM Reply With Quote
clutch problems
Just been out for the sunday morning blat and destroyed the clutch. The clutch is rover sd1 2000 item and was always going to be the weak link and ime kicking myself now for not sorting it out at an earlier stage.Really dont want to change flywheel, starter motor etc etc. Question is can i send my old clutch some where to be heavily uprated?
thanx for any help
UncleFista
posted on 22/11/09 at 11:44 AM Reply With Quote
Isn't there a diesel version of the same clutch ?
It's usually the first port of call if you're after a heavy duty item.
Tony Bond / UncleFista
t16turbotone
posted on 22/11/09 at 11:50 AM Reply With Quote
ime wondering wether i drill and tap my flywheel to take RV8 cover and plate as ime using LT77 gearbox?
blakep82
posted on 22/11/09 at 11:53 AM Reply With Quote
i'd have thought the sd1 clutch was more than up to the job. the sd1's a heavy car, and your car will be a lot lighter
________________________
t16turbotone
posted on 22/11/09 at 12:07 PM Reply With Quote
Yes i thought that at first, but the o series that was fitted to the sd1 2000 didnt produce 200 ft/lb torque
gregs
posted on 22/11/09 at 12:15 PM Reply With Quote
how did it fail - catastrophic or slipping more and more?
Was the clutch new when you fitted it, or recycled?
t16turbotone
posted on 22/11/09 at 12:23 PM Reply With Quote
The clutch was new in a box but i remember thinking mmmhhh this looks crap....600 miles and its slipping under boost, just got me thinking about wether the hydraulic system may be faulty in some way?
gregs
posted on 22/11/09 at 03:25 PM Reply With Quote
there's two ways round that then. check you haven't got the release preloaded, ie the it's loose when clutch pedal not pressed. If not, back off the push rod. If that's ok, then you need a pressure plate with higher clamping pressure - unfortunately I don't fancy your chances of finding one....
Might be easier to upgrade.
For info, there is a SD1 2600 (i think) in the scrappy at earlswood which might source the flywheel starter and all.
ss1turbo
posted on 22/11/09 at 06:22 PM Reply With Quote
For a one-stop-unblowupable clutch, then Helix might be worth a call.
216mm or 241mm clutch? I suspect the 216 if its gone already. Just had a look in my catalogue and the 2000 SD1 isn't listed, but found the Sherpa instead which came a 216mm (4 speed) or 241mm (5 speed) one..
The 241mm one is the same as the V8
Long live RWD...
