Author: Subject: Oil Cooler Mounting
phelpsa
posted on 22/12/09 at 11:32 PM Reply With Quote
Oil Cooler Mounting
Is there any reason why i cant mount my oil cooler in this position, but the other way up (ports at the bottom) and slightly higher up so the top of the cooler is in line with the top of the chassis?
It would allow me to use the hoses that came with the cooler and protect the cooler in case of a bump (it's probably the most valuable thing on the car....).
Adam
Steve Hignett
posted on 23/12/09 at 12:31 AM Reply With Quote
Only reason I would guess at is a lack of "forced" colder air...
So if your main priority is the safety of the cooler (and it certainly see,s large enough to cool a BEC in any position!) then it should be fine where you've got it!
blakep82
posted on 23/12/09 at 12:55 AM Reply With Quote
hmm, it is quite big will probably cool well enough without any direct air flow at it
________________________
RAYLEE29
posted on 23/12/09 at 09:58 AM Reply With Quote
Cool add some ducting and a fan if needed Ray
tegwin
posted on 23/12/09 at 10:35 AM Reply With Quote
Christ thats a big oil cooler.... are you running a veyron engine or something?
www.verticalhorizonsmedia.tv
TimC
posted on 23/12/09 at 11:15 AM Reply With Quote
Erm, erm... looks perfect to me....
I may have bought a very similar one.. :s
franky
posted on 23/12/09 at 11:24 AM Reply With Quote
make sure its got an oil stat fitted otherwise your oil will never reach its operating temp.
I'd try to mount it on a rubber bush or the like as they're sensitive to HF vibration.
phelpsa
posted on 23/12/09 at 11:28 AM Reply With Quote
How about an oil cooled GSXR engine
I'll be running it with a fan so there'll be some forced air flow.
The shouldnt be any issues with mounting it 'upside down' though?
tegwin
posted on 23/12/09 at 11:35 AM Reply With Quote
Agh that makes sence..... too much mulled wine! (eughhh)
flak monkey
posted on 23/12/09 at 11:36 AM Reply With Quote
Oil coolers must be mounted with the ports at the top otherwise you can get air trapped in them.
Sera
http://www.motosera.com
phelpsa
posted on 23/12/09 at 11:56 AM Reply With Quote
Bad news. Cheers David, looks like im gonna have to stop being a stingy barsteward and buy some new hoses. I'm thinking it may be better to mount it on the front for maximum air flow then and just try not to crash it
phelpsa
posted on 25/12/09 at 01:17 AM Reply With Quote
Went for the conventional mounting position:
