flak monkey
| posted on 26/12/09 at 11:55 AM |
Looking for some idler pulleys
I am looking for 3 idler pulleys, with a plain OD to run on the back of my aux belt on the duratec.
I need 2 60mm OD ones and 1 40mm OD one.
Does anyone know of any standard idler pulleys which are around this sort of size and are fixed with a single bolt through the centre?
If it comes to it I could make some, but if they are off the shelf it would be nice.
Thanks,
Sera
http://www.motosera.com
Myke 2463
| posted on 26/12/09 at 12:33 PM |
Hi Dave.
What about double row ball bearings.
40mm dia x 16mm wide x 17mm internal 4203
62mm dia x 24mm wide x 25 mm internal 4305
alternative A T Johnson have lots of data on std items.
Mike.
flak monkey
| posted on 26/12/09 at 12:35 PM |
Thanks Mike, will have a word in AT's next time I go in there.
The idlers need to be wide enough for a 6groove poly vee belt. About 1" wide I think.
Sera
CRAIGR
| posted on 26/12/09 at 01:23 PM |
Standard impreza cambelt ones are about 60 mm i think.
gazza285
Berlingo? Two bolt fixing, but one is through the centre, sure a man of your capabilities can cut off the excess though.
CRAIGR
| posted on 26/12/09 at 01:25 PM |
Pics of what i mean
hillbillyracer
| posted on 26/12/09 at 01:30 PM |
We've just been putting an engine in an LDV Maxus van, the aux belt idlers are about 60mm or a touch bigger at a guess & bolt on with a
single central bolt. The belt is a 6 rib one & they're plain to run on the back of it. The cam belt uses a similar if not the same idler
too
Cam belt idlers on a Maestro diesel are about 40-50mm & run on the back of the belt, again a single central bolt.
That's just things that are off the top of my head, mabye best to go to a scrappy & have a look & see what you can find? Some yards are
still happy enough to let you wander around to find something, others are not interseted & you have to know excactly what you want & ask for
it.
flak monkey
| posted on 26/12/09 at 09:53 PM |
Brilliant, thanks a lot guys
Will have a look and see what I can find.
Sera
