The Knobs
| posted on 27/12/09 at 11:01 PM |
Totota 4age 20v gaskets
Anyone know the best place to source 20v gasket set for an engine strip and rebuild ? Not sure if they can be ordered through any Toyota dealer being
an import engine.
turbodisplay
| posted on 27/12/09 at 11:05 PM |
I bought a gasket set from ebay for a 3sgte.
Apart from the cork sump gasket leaking, it has worked fine.
Darren
The Knobs
| posted on 27/12/09 at 11:11 PM |
So all the gaskets fit ok with enough and the right holes in the head gasket, and does it come with bolts ? I will use sealant for the sump anyway.
turbodisplay
| posted on 27/12/09 at 11:16 PM |
Yep, they were good,exact fit, head was for a later version as i wanted a metal head gasket, done 1000 miles so far, head gasket has been fine.
Oil seals were good quality.
Darren
[Edited on 27/12/09 by turbodisplay]
bimbleuk
| posted on 28/12/09 at 06:59 AM |
an import engine.
Fensport might still stock the gasget sets.
You can get most parts from the Toyota dealers for them. I needed the hydraulic cam belt tensioner recently. I down loaded the Toyota EPC and found
the part number. I printed the part picture with numbers and made sure it matched what the parts department were going to order.
Luckily they had one in stock in the UK so there's probably a lot more parts sharing that we realise.
I don' think there are any Toyota sump gaskets. The closet I know of is for the 7AFE. Even then only Chrysler fitted one as they used the engine
as well.
[Edited on 28-12-09 by bimbleuk]
Worzey
| posted on 28/12/09 at 10:51 AM |
I got a head gasket from Fensport (back in May) so that would be my first call. Excellent service as well.
Pete Jordan
| posted on 28/12/09 at 11:00 AM |
You could also try BPJ Services, who build/modify 4AGE 16V and 20V variants.
LINKY
Pete
Worzey
| posted on 28/12/09 at 11:38 AM |
If I recall correctly, BPJ Services didn't stock the gaskets the last time I tried hence the call to Fensport and the shinney new TRD gasket.
They may have them now so this would be my second call.
Both companies offered excellent service as I have used them both several times in the past.
Caterham R400
Werner Van Loock
| posted on 28/12/09 at 12:23 PM |
last resort?
silvertop 20v ebay
blacktop 20v ebay
whenever looking for 4age parts on ebay internationally search for 4ag* as the 4age is mostly referred to as 4ag
[Edited on 28/12/09 by Werner Van Loock]
http://www.clubstylus.be
COREdevelopments
| posted on 28/12/09 at 02:51 PM |
toyotas never came with sump gaskets. they used grey sealer called ultragrey. but any good quality sealer will be good. toyota dealers can get the
majority of import parts. it helps if you know the model code and the 1st few digits of the chassis number. also helps if you got a good parts guy
behind the counter too as some cant be bothered.
Rob
blockhead_rich
| posted on 19/1/10 at 09:42 PM |
Hi
I might be able to obtain a head gasket set Part No. 04112-16210 > see the following web page for info >
http://opc.mr2oc.com/online_parts_catalog/20v/gasketkit-overhaul-valvegri.gif
For about £100. Would you be interested
Rich
