Author: Subject: ZX6r Carbs. NOOB question..... sorry
dan8400
posted on 28/12/09 at 07:45 PM Reply With Quote
Do all ZX6r carbs have TPS. This will be my first megajolt project engine so it's all new. I've done lots of reading on the old posts about which carbs and how to fabrictace an inlet manifold etc etc.
I need to know when ZX6r carbs started having TPS or do they all have it.
Dan
mookaloid
posted on 28/12/09 at 07:49 PM Reply With Quote
I can't help you with an answer, but there's no need to apologise for asking
We all ask questions, that's what the forum is for
Mark
deltron63
posted on 28/12/09 at 07:50 PM Reply With Quote
g1 g2 models have
dan8400
posted on 28/12/09 at 07:53 PM Reply With Quote
Thanks Mark
Sometimes feel a bit daft asking when i've read um-teen old posts about similar subjects.
Maybe i'm too nice lol
Dan
woolly
posted on 28/12/09 at 08:02 PM Reply With Quote
j2 models aswell
some on the bay but very dear
woolly
dan8400
posted on 28/12/09 at 08:04 PM Reply With Quote
ok so i'm looking for g1 g2 and j2
thank you guys
Any idea on bike model years?? Some ebayers don't answer their questions (ie: "do the carbs have a throttle position sensor"
Most just put model year etc
Dan
[Edited on 28/12/09 by dan8400]
blakep82
posted on 28/12/09 at 08:05 PM Reply With Quote
to add to the mix, don't forget zx9r carbs
mine (i don't know the particular model) has TPS too
jacko is the man to ask about zx9r carbs
________________________
dan8400
posted on 28/12/09 at 08:08 PM Reply With Quote
I read 600cc bike carbs are ok for 1.8 silver top zetec.
Can i go larger?? ie: 1000cc or 1100cc
Not sure how i go about jetting/setting up etc... many on here use or have used BOGG BROTHERS.....?? seems the way to go
Dan
blakep82
posted on 28/12/09 at 08:11 PM Reply With Quote
i've been told anywhere from 600cc to 1100cc bikes carbs are ok. in just about every case, you'll need the jets redrilled.
i had zzr1100 carbs for my 2.0 vauxhall engine, but they didn't have TPS, so i got zx9r carbs
the jets on mine will need drilled to about 1.5-1.6mm, yours perhaps slightly less.
have a look at this thread for example. it lists just about every carb going
http://www.locostbuilders.co.uk/viewthread.php?tid=107223
[Edited on 28/12/09 by blakep82]
ashg
posted on 28/12/09 at 08:18 PM Reply With Quote
mine are g and they come with tps. i think all the carbs after g1 have tps but im not 100% sure.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
RichardK
posted on 28/12/09 at 09:08 PM Reply With Quote
I used these hornet carbs LINKY DINKY DO DA
Do come with tps, drill out to 1.65 and bobs your uncle, fannies your aunt and dicks your best friend!
Rich
Gallery updated 11/01/2011
dan8400
posted on 28/12/09 at 10:19 PM Reply With Quote
how do i drill the jets?
is it just to literally drill through to make the petrol hole bigger?
Dan
blakep82
posted on 28/12/09 at 10:25 PM Reply With Quote
pretty much. you unscrew the jet out the bottom of the carb, and take a drill of the correct size to it
dan8400
posted on 28/12/09 at 10:31 PM Reply With Quote
is it still advisable to have it set up rolling road stylee? or see how it goes?
Dan
RichardK
posted on 28/12/09 at 11:02 PM Reply With Quote
I did have a rolling road session and the air correctors got blocked off so always worth doing if they know about bike carbs just to make sure they are giving you the best power but 1.65 should give you a useable car to drive to the rolling road!
I have some spare 1.65 drlils if you need 1!
Rich
dan8400
posted on 29/12/09 at 12:04 AM Reply With Quote
u2u sent
Thanks Rich
Dan
ashg
posted on 29/12/09 at 09:02 AM Reply With Quote
personally i wouldnt touch the jets.
when i had mine set up they didnt need to re drill the jets.
they reprofiled the needles which was enough.
you only need to redrill the jets if the car is underfueling past 4.5k if its underfueling below 4.5k the needles need reprofiling or you will lose your fuel economy on cruse.
they are near impossible to seup without a wideband lambada so if you dont have one just take it to the rr. i can reccomend atspeed in essex if your in the south
dan8400
posted on 29/12/09 at 09:19 AM Reply With Quote
I'm in lincolnshire. Boston area. I think bogg brothers are in yorkshire somewhere, so may be worth a day trip out.
Unless anyone knows of anyone in my area
Dan
whitestu
posted on 29/12/09 at 10:27 AM Reply With Quote
I'm running ZX6Rs on a 2.0 Zetec and they work great. Jets are drilled to 1.6mm and needles are adjusted to get mid range mixture right. I set mine up with a wide band lambda.
The standard size jets are likely to be too small on a 1.8 Zetec [depending on what air filter / airbox you are running]. The biggest danger with DIY carb setups is running too lean, hence the need for a wideband or better still an RR session.
Stu
