Author: Subject: Bolting down a RV8 inlet manifold
scudderfish
posted on 8/1/10 at 09:49 AM Reply With Quote
I have a collection of different length bolts for my inlet manifold. The Haynes SD1 manual helpfully says "The bolts are of differing length so take note of their exact locations". I wish I'd read that before I took them out....
Does anyone know which one goes where?
Regards,
Dave
jollygreengiant
posted on 8/1/10 at 10:02 AM Reply With Quote
Measure the depth of the holes and locations of those holes (including the maifold), then compare the lengths to the bolts and allow a bit extra for clearances. Then sort as appropriate.
This method has never let me down.
Mr Whippy
posted on 8/1/10 at 10:13 AM Reply With Quote
^ ditto, quite straight forward really
posted on 8/1/10 at 11:32 AM Reply With Quote
is not possible to work out from the manifold?
refer to phjoto below.
the bolt in the lower left hand corner fits into a raised boss compared to the other 4 bolts alon the lwer edge - hence that wold need longer bolt.
note that if you have skimmed the heads a lot, you will have fun getting the manigold and metal sheet gasket to correctlyand seal.
Canada EH!
posted on 8/1/10 at 03:12 PM Reply With Quote
How about a nice Edelbrock Buick manifold and a 4 barrel Edelbrock carb, what do they bolt to that, 2 side draught SU's
