Author: Subject: Which 2.0 zetec, Blcktop or silvertop?
rich201283
posted on 11/1/10 at 09:40 PM Reply With Quote
Which 2.0 zetec, Blacktop or silvertop, Which one is the best to fit, Does the blacktop have more power? What is the difference?
whitestu
posted on 11/1/10 at 09:46 PM Reply With Quote
In theory at least the blacktop is better - has solid lifters and lighter pistons [I think].
However, whichever is cheapest and closest to you is probably best if you are keeping it standard.
Stu
zetec
posted on 11/1/10 at 10:21 PM Reply With Quote
Older engines had the advantage of easier pass for SVA, not sure what new regs say.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 11/1/10 at 11:04 PM Reply With Quote
Blacktop's are easier to chop the sump but need an idler.
skodaman
posted on 11/1/10 at 11:47 PM Reply With Quote
Check IVA rules. Under old rules non-cat engines had to be something like pre-aug 96. Which meant even late silvertops would require a cat. If u don't want a cat and all the associated complications fit a silvertop then change to blacktop after IVA. Blacktop is slightly better engine, but silvertops are still very good.
Skodaman
FFTS
posted on 12/1/10 at 01:18 AM Reply With Quote
I have a 2.0 Blacktop and gearbox from a Mondeo with 76.000 I believe, complete with ecu loom and all bits on a pallet and to be sold if anyone is interested.
I bought it to put in an Indy and then bought a BEC so the engine is surplus to requirements.
Chris.
rich201283
posted on 12/1/10 at 05:57 AM Reply With Quote
From what i have read i believe Q reg cars are exempt from this reg and only need a visual smoke test, Is this correct?
big_wasa
posted on 12/1/10 at 06:41 AM Reply With Quote
yours is allready reg'ed so you can fit whtat you like age wise.
Ive got both and like the silver tops better due to sump and water pump set ups.
rich201283
posted on 12/1/10 at 08:24 AM Reply With Quote
On the zetec e engines - Does the type 9 box still fit as i have read the startor is further up?
stevebubs
posted on 12/1/10 at 01:07 PM Reply With Quote
Yes, and you'll need a 1.8 CVH starter...
