bodger
| posted on 19/1/10 at 04:25 PM |
Supplier of 10-9 Bolts & Set screws ?
Can anyone point me in the direction of a supplier for some 10-9 Metric Fine thread bolts & set screws? They are for bolting the prop-shaft to
prop-shaft adapter & rear diff. Can't use Ford replacement Bolts cause I need them another 5mm longer to fit my Reverse Spur gear. Namrick
don't do 10-9 ( I live around the corner - thank god!).
Most places on the net only supply in bulk quantites.
T66
| posted on 19/1/10 at 04:35 PM |
Ive used Potters for a long time
Not sure if they post though ..
http://www.thomaspotter.com/
| posted on 19/1/10 at 04:38 PM |
Have you looked for 12.9 grade bolts?
There might be a wider choice although they'll likely be cap heads (not an issue).
mcerd1
| posted on 19/1/10 at 05:08 PM |
^^^ what he said try 12.9 cap heads (alan key ones)
we use McLean Buchanan & Wilson at work all the time and potters as well
either of them will be able to get what you want
JekRankin
| posted on 19/1/10 at 06:26 PM |
I've been looking out for a similar supplier too - Namrick unfortunately only do 8.8 grade bolts with hex heads. (I'm after hex heads
instead of cap heads so I can use lock tabs)
Anyone know if McLean Buchanan & Wilson or Potters will do mail order to non-trade customers? I'll give them a call tomorrow and see what
the set up is.
Jek
mcerd1
| posted on 19/1/10 at 06:57 PM |
^^ MBW should be just down the road from you
if folk are stuck and/or there is a bit of interest I can get them through my work and post them out
[Edited on 19/1/10 by mcerd1]
bodger
| posted on 19/1/10 at 07:01 PM |
Thanks, if I don't get anywhere with MBW or Potters I might try this place I just found on ebay.
Linky
[Edited on 19/1/10 by bodger]
JekRankin
| posted on 19/1/10 at 09:07 PM |
D'oh, I completely forgot - I tried MBW for some nuts and bolts before xmas, but they're trade only unfortunately! :-)
I've just discovered that the OEM prop bolts from a Sierra have a blue coating so I'll try to get them from Ford. Hopefully they can
supply caliper bolts too. Thanks for the kind offer, though! :-)
Jek
mcerd1
| posted on 19/1/10 at 10:06 PM |
that'll be the thread lock
I should have a spare set somewhere - if I can find them....(my dax prop came with new cap heads)
mad4x4
| posted on 20/1/10 at 07:17 AM |
What about namrick and use a 12.9 as this will be stronger than a 10.9
Someone will be along to say "stronger" is not the right description and say
"Actually it is Tensile strenght which is ..... Blah Blah Blah"
[Edited on 20/101/10 by mad4x4]
Scot's do it better in Kilts.
