Miks15
posted on 29/1/10 at 03:17 PM |
Ford Focus engine won't start
I've installed a secondhand engine in a Ford Focus 03 reg. I cannot get the engine started and have come to the point where I am sure that it is
a timing problem. The engine came out of a car with automatic transmission (mine is manual) and as far as I can see there is at least a 20 degree
difference in the timing mark on the flywheel for the cranksensor between the two engines (everything else is indentical).
I have heard that the same kind of problem can occur if people put a dualmass flywheel on a ford.
Any ideas how I can get around this?
big_wasa
| posted on 29/1/10 at 05:39 PM |
I know the solution but your not going to like it as you will have to take the engine back out
Miks15
| posted on 29/1/10 at 05:40 PM |
Whats the solution.. its been in and out many times so getting used to it
big_wasa
| posted on 29/1/10 at 05:45 PM |
The Crank position sensor housing is differant between auto and manual.
see pic
change for the one on your old engine and it will go if its a zetec black top ?
[Edited on 29/1/10 by big_wasa]
Miks15
| posted on 29/1/10 at 06:50 PM |
ahh could explain it, cheers wasa
big_wasa
| posted on 29/1/10 at 07:45 PM |
I know this has caught many out on the silver and black top engine. you didnt say what engine your focus is but well worth a look.
Miks15
| posted on 30/1/10 at 06:55 PM |
got the engine going, cheers wasa! Locostbuilders hasnt failed me yet!
