Author: Subject: Filter King to Fireblade carbs fuel line
norfolkluego
posted on 29/1/10 at 11:26 PM Reply With Quote
having a spot of bother joining one to t'other.
Filter King output seems to need a 5/16th (8mm) hose, the carbs seem to need 3/8th (10mm) hose, can't force the 8mm onto the carbs and the 10mm won't tighten properly onto the filter,is it OK to use a brass hose joiner such as the CBS ones like (http://www.cbsonline.co.uk/brass-reducing-joiner-8mm-to-6mm--bred86-1809-p.asp), are they safe to use.
[Edited on 29/1/10 by norfolkluego]
austin man
posted on 29/1/10 at 11:32 PM Reply With Quote
car builders solutions can supply 8mm to 10mm connectors
norfolkluego
posted on 29/1/10 at 11:34 PM Reply With Quote
Sorry should have said I know that's the wrong size but the 10mm to 8mm didn't have a picture
austin man
posted on 29/1/10 at 11:39 PM Reply With Quote
I fitted the plastic CBS ones as I had a 10mm pipe going on to an 8mm pump, no problems in 3 years
jacko
posted on 30/1/10 at 11:29 AM Reply With Quote
I use a air line connector
8mm to 10mm pipe to pipe
