Author: Subject: tintop issue
55ant
posted on 5/2/10 at 09:06 PM Reply With Quote
tintop issue
hi all,
when slowing to a stop in the tintop sometimes the revs drop really low, its now died twice in the last few days as a result, anyone know what this may be? other than this the car drives fine?
away from cars, now cycling and building TT bikes
big_wasa
posted on 5/2/10 at 09:07 PM Reply With Quote
lots of info here
link
If you want a spare idle controle valve I have one that I was going to bin that you can have.
[Edited on 5/2/10 by big_wasa]
tomgregory2000
posted on 5/2/10 at 09:09 PM Reply With Quote
ICV playing up?
What car?
big_wasa
posted on 5/2/10 at 09:12 PM Reply With Quote
They also suffer from air leakes around the egr. Spay some wd40 around the hosses and sea if the revs pick up.
Is this your budget mondeo ?
55ant
posted on 5/2/10 at 09:13 PM Reply With Quote
its the missus' 1.2 corsa c.
graememk
posted on 5/2/10 at 09:16 PM Reply With Quote
i think you will find its the crank sensor...
55ant
posted on 5/2/10 at 09:21 PM Reply With Quote
cheers all, ill have a look in the mornin, the mondeo! no, that things a tank, i heard a rumor saloon cars dont go wrong? hope thats true!
graememk
posted on 5/2/10 at 09:27 PM Reply With Quote
corsa web forum
posted on 6/2/10 at 10:40 AM Reply With Quote
Almost certainly the EGR valve carboned up.
Typical Vauxhall clean or better blank off the EGR valve and clean the idle control valve.
And clean the breathers.
With the Corsa I would advise using only fully synthetic 5w/30 in the sump it reduces the carbonisation problems these engine tend suffer from.
Unlikely to be the crank sensor as the engine is stalling because the revs are dropping too low.
With crank sensor failure the engine just stops dead.
[Edited on 6/2/10 by britishtrident]
