MakeEverything
| posted on 7/2/10 at 03:05 PM |
TURBO MAP?
Hi All,
Well if youve been following my progress, ive fitted the turbo, and took it for a spin to the SG7 meet.
Apart from an oil leak from the turbo feed (jubilee clip not fitted properly / thread stripped) it worked very well.
I am disappointed though, as i was expecting some very agressive power but all i seem to have got is a slight increase and about 1/3 more torque.
Does anyone have a compressor map for a TD04 turbo? I want to check the map to see where i am in the pressure maps, and make sure the turbo is large
enough for the installation before i go any further.
It makes a great sound when it spins up, and there is a noticeable difference, just not as much as i was expecting.
now, where did i put that supercharger....
Kindest Regards,
Richard.
MakeEverything
| posted on 7/2/10 at 03:10 PM |
found it
http://www.rbracing-rsr.com/turbo/TurboMaps/td04-13g.gif
Kindest Regards,
Richard.
flak monkey
| posted on 7/2/10 at 03:11 PM |
This'll be what you need
There are a load more here:
http://www.stealth316.com/2-3s-compflowmaps.htm
For different versions of the TD04 turbo. Links are just over 1/3rd the way down the page.
Do you know what boost you are getting and what AFR under boost?
[Edited on 7/2/10 by flak monkey]
Sera
http://www.motosera.com
oadamo
| posted on 7/2/10 at 03:53 PM |
what psi are you running because on most turbo cars you only get a good kick when your running 15psi boost.
adam
Volvorsport
| posted on 7/2/10 at 04:27 PM |
what compressor do you have ?
www.dbsmotorsport.co.uk
getting dirty under a bus
t16turbotone
| posted on 7/2/10 at 04:39 PM |
Thats strange...I have the same unit fitted to my engine, when boost comes in its savage, pretty frightning really. Ime looking to tone it down a
little
MakeEverything
| posted on 7/2/10 at 04:55 PM |
adam
I dont know at themoment, as the gauge i wanted to use will be facing the wrong way, so i installed the boost controller and wound it in to
"About that much" boost pressure! I know, i know, the risks of blowing up the engine etc etc...
I think i might remove it and try again with the standard actuator on its own, but once ive stopped the oil leak and cleand up a bit.
Kindest Regards,
Richard.
jacko
| posted on 7/2/10 at 06:29 PM |
quote: Originally posted by MakeEverything
Hi All,
Get that oil feed repaired properly a mate of my son lost his skyline in a massive fire when the same pipe came off his turbo and sprayed oil over the
engine /exhaust hi was very lucky to get out the car alive
jacko
MakeEverything
| posted on 7/2/10 at 06:35 PM |
Hi All,
jacko
Yep, roger that. It smoked loads when i floored it when a Hummer tried to tailgate me.
Kindest Regards,
Richard.
Volvorsport
| posted on 7/2/10 at 06:46 PM |
if thats a 13c on there , you should be pulling full boost by about 2500 rpm
MakeEverything
| posted on 7/2/10 at 06:56 PM |
Thats what worries me. !!
Need to get an Air Fuel meter to find out if its a fuel problem.
Kindest Regards,
Richard.
