Author: Subject: Type 9 rebuild, how much of a bitch is it?
Jasongray5
posted on 7/2/10 at 11:10 PM Reply With Quote
As per title really, there is abit of movement on my input shaft and i would rather rebuild it now, when its not installed in the car!
Using one of these kits here, does anyone know what its like to do?here
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
Chippy
posted on 7/2/10 at 11:42 PM Reply With Quote
Hi, if you get hold of the Haynes book on gearbox O/haul it covers the Type 9. I did mine and its very easy if you follow the book. HTH Ray
Jasongray5
posted on 8/2/10 at 12:15 AM Reply With Quote
cool thanks Ray,
Do you need any specialist tools? and roughly, how long did it take you?
Jas
How hard can it be?
flak monkey
posted on 8/2/10 at 08:04 AM Reply With Quote
Its normal to have some movement on the input shaft
They arent that difficult to rebuild. You'll need some gear pullers, pin punches and some large circlip pliers though.
Sera
http://www.motosera.com
Chippy
posted on 8/2/10 at 02:49 PM Reply With Quote
flak monkey
Hi Flak, can't think where you need gear pullers!!
Jasongray5
You will need some circlip pliers, and I found a good blow lamp to heat up the casings made it easier to remove and replace the bearings. Think I did mine in a day, not a big job! I would agree with David though, regarding the movement in the drive shaft, you do get side to side movement, as one end is supported by the bearing in the flywheel, so you are just relying on one bearing without that. Cheers Ray
flak monkey
posted on 8/2/10 at 03:40 PM Reply With Quote
You need a puller to pull 5th gear off the layshaft.....
Sera
Chippy
posted on 8/2/10 at 11:05 PM Reply With Quote
Ah! yes quite correct, long time since I did mine, but thinking about it I used a couple of tyre levers I think, certainly don't have a puller. Cheers Ray
