Author: Subject: K series High Idle speed
matty h
posted on 8/2/10 at 11:29 PM Reply With Quote
I have a 1.8vvc 143bhp k series in my GTM Libra it seems to have a problem as it sometimes does not idle and will sit at 2500 rpm and today it was sat at 3500rmp.
It has a 48mm ali throttle body and I have checked the inlet manifold for leaks but did not have any.
Anyone got any suggestions.
Major Stare
posted on 8/2/10 at 11:53 PM Reply With Quote
If you get no answer on this forum, try this one....http://forums.mg-rover.org/
Jon "FISH"
posted on 8/2/10 at 11:57 PM Reply With Quote
You may need to clean and/or reset the idle valve.
steve m
posted on 9/2/10 at 09:54 AM Reply With Quote
i have the opposite, my k series idles from cold at about 800rpm
and untill the needle is 2/3 up the scale, it can be a real pain driving, as it stalls
(thats in my road car)
Hammerhead
posted on 9/2/10 at 12:21 PM Reply With Quote
throttle position sensor?
matty h
posted on 9/2/10 at 08:35 PM Reply With Quote
I have cleaned the idle control valve out will see tomorrow if it has worked otherwise may need to check the throttle position sensor how do I know this is working correctly.
posted on 10/2/10 at 05:15 PM Reply With Quote
Check the inlet manifold is tight on the head.
matty h
posted on 11/2/10 at 05:41 PM Reply With Quote
Cleaning idle control valve seems to of done the trick took more than the 20 mins stated on the link more like an hour.
