Author: Subject: little help please
boggle
posted on 9/2/10 at 07:54 PM Reply With Quote
little help please
looking at fitting my rad tommorow eve and im thinking i need some guidance to plumbing it all up.....
i have a 2.0 pinto.....no heater matrix to worry about, just the rad, header tank and intake manifold to suss.....my water pump has a large outlet (to bottom of rad) and a small outlet (to inlet manifold and bottom of header tank?)
then thermosat housing to top of rad??
am i some where close?
ta
boggle
u2u me for details
DRC INDY 7
posted on 9/2/10 at 08:08 PM Reply With Quote
yep very close with mine ive got the pipe from the thermo house going to the expansion bottle inlet at the top
Puddle Dodgers Club
Mr Whippy
posted on 9/2/10 at 08:15 PM Reply With Quote
the small pipe coming out of the water pump usually is used to supply the heater matrix but if your not using that then it should be connected to the water inlet on the inlet manifold instead to keep that warm. The large pipe coming of the thermostat housing is the hot side and goes to the top of the rad. The cold bottom rad connection goes back to the water pump.
[Edited on 9/2/10 by Mr Whippy]
contaminated
posted on 9/2/10 at 08:20 PM Reply With Quote
What they said.
l0rd
posted on 9/2/10 at 08:34 PM Reply With Quote
Originally posted by contaminated
What they said.
+1
MakeEverything
posted on 9/2/10 at 10:24 PM Reply With Quote
Not entirely necessary though. I had a mini that had this arrangement, and i never connected it. It worked fine.
Kindest Regards,
Richard.
