Author: Subject: twin 48 dcoes
boggle
posted on 15/2/10 at 10:19 AM Reply With Quote
twin 48 dcoes
anyone ever fitted them to a pinto???
worth looking in to?
u2u me for details
mcerd1
posted on 15/2/10 at 10:23 AM Reply With Quote
loads of them on high spec pinto's - but if you've not got massive valves and alot of porting done to the head then they will be a bit OTT
if your engines fairly standard then 40's should be plenty
couch22k
posted on 15/2/10 at 10:34 AM Reply With Quote
Ive got Dellorto 48's on my 2.1 pinto, but as said ive got a stage 3 head and high lift cam. Not sure of bhp yet. Hoping to get it on a rolling road soon.
boggle
got a single 48 on at the mo, but in time i would look for another then do some major engine rework......
[Edited on 15/2/10 by boggle]
u2u me for details
couch22k
posted on 15/2/10 at 10:40 AM Reply With Quote
Well worth it, it does sound sweet..
mcerd1
posted on 15/2/10 at 10:46 AM Reply With Quote
the key thing is to match the spec of all the bits
No point in getting twin 48 sorted out unless you've got the valves, ports, cam, etc. to match - it'll only be as good as its weakest part (think how much power each bit is good for)
and if your carbs are too big for your engine you'll lose drivability
[Edited on 15/2/10 by mcerd1]
mookaloid
posted on 15/2/10 at 12:33 PM Reply With Quote
I can't think of a good reason to want to put 48's on a pinto.
you only need 48's if you are going over say 200 - 220 bhp.
To get a pinto to that sort of power you would be looking at spending thousands of £££££'s and if you are going to spend that much you might as well go for a Duratec with proper throttle bodies. which will be a better, lighter engine.
So twin 45's would be all you would ever need in the real world, but even then you would probably need to spend £1000 -£1500 on the motor to make tham worthwhile.
If you just do a bit of head work and stick with standard components and a mild cam anything from a 38DGAS down draft, a single 45 DCOE or twin 40's will if set up correctly be fine.
Mark
mcerd1
posted on 15/2/10 at 12:57 PM Reply With Quote
I forgot to add: what about bike carbs ?
ZX9R / R1 carbs are about the right size for a warm pinto (good for say ~160bhp I think)
there are bigger bike carbs if they arn't enough for you and manifold shouldn't give you any problems
flak monkey
posted on 15/2/10 at 01:06 PM Reply With Quote
No point, the port on the head is OD 36mm and thats still too big for anything under 220bhp.
The best sized chokes for even the most highly tuned pinto is 38mm. 36mm is best for most. Both of which will fit in 45's
Sera
http://www.motosera.com
blakep82
posted on 15/2/10 at 02:09 PM Reply With Quote
i'd have thought twin 45s would be the biggest you'd need
________________________
boggle
posted on 15/2/10 at 03:01 PM Reply With Quote
just a thought...
if i was to take my pinto to more than 180bhp would i then need to be looking at changing my type 9 box?
u2u me for details
flak monkey
posted on 15/2/10 at 03:06 PM Reply With Quote
Originally posted by boggle
just a thought...
Youd bet better off looking at a different engine for more than 180bhp.
An no, no need to uprate the box until you hit about 250bp.
Sera
boggle
posted on 15/2/10 at 03:19 PM Reply With Quote
hoping the engine is around 120 at the mo all being well i reckon i could get 150....would i need anymore???
that would be near 300hp per ton?
u2u me for details
blakep82
posted on 15/2/10 at 05:56 PM Reply With Quote
as a sort of idea, the racing trucks like mine, they run twin 48's with 38mm chokes, but put out 230bhp.
