Flick
| posted on 15/2/10 at 09:48 PM |
1.8 ZETEC WATER PUMP
Hi
Ive got a 1.8 silvertop zetec.. Been told I may have to change the waterpump as it may go the wrong way...any truth in this
austin man
| posted on 15/2/10 at 09:59 PM |
if the engine is from the mondeo the water pump turns the wrong way the escort pumps are what you need.
paulf
No the 1.8 pump is the correct one to use,2.0 engines need an idler pulley or 1,8 pump to get the correct direction of rotation.
Paul.
Flick
| posted on 15/2/10 at 10:23 PM |
its a 1.8l from a mondeo, so do i need a new waterpump from an escort?
FazerBob
| posted on 15/2/10 at 11:46 PM |
Hi Flick,
I fitted a Mondeo 1.8 Silvertop Zetec to my car. You will DEFINITELY need to change the water pump. The pump you need is from a Mk4/5 Escort.
Take your old pump with you for comparison. The correct Escort pump will look identical EXCEPT for the impellor vanes, which curve in the opposite
direction.
You will also need to fit a grooved pulley to your new pump as you will be driving it from the inside of the belt, and not on the outside as in the
Mondeo.
Bob
Flick
| posted on 15/2/10 at 11:51 PM |
thanks mate
[Edited on 16/2/10 by Flick]
Steve G
| posted on 16/2/10 at 12:09 AM |
If you're fitting a fairly unknown engine then i'd change the water pump and cam belt kit as a matter of course regardless of its
rotation. Changing the water pump is a cambelt off job and tough to do when in the car so for what they cost........
Flick
| posted on 16/2/10 at 12:17 AM |
Not fitted the engine yet, trying to get everything right before fitting. Knowing my luck ill fit it and end up having to remove it several times to
rectify errors made...................... Im beggining to think I should of stuck with bike engines..................
| posted on 16/2/10 at 10:20 AM |
Pumps don't turn the wrong way, they just turn whichever way Ford intended.
If the pump pulley is smooth it runs off the back of the belt which is conterclockwise IE: 'wrong'
If the belt has grooves aka the belt it goes clockwise UE: 'right'
So, heres mine, smooth pulley running 'wrong'/'backwards'.
Hope that helps.
| posted on 16/2/10 at 11:15 AM |
Unless you re-route the drive belt, then they get turned the wrong way...
