Author: Subject: External Brake Servo?
rich201283
posted on 24/2/10 at 08:29 AM Reply With Quote
What car can i get an external brake servo as i have not got enough room to mount on the brake master cylinder?
r1_pete
posted on 24/2/10 at 09:27 AM Reply With Quote
Many 60's and early 70's cars had remote servo's, MGB, Cortina, Classic, Consul Capri, Hilmans etc...
Heres a selection.
big-vee-twin
posted on 24/2/10 at 01:57 PM Reply With Quote
CBS make one linky but you may not want to pay that much
http://www.triangleltd.com
posted on 24/2/10 at 02:33 PM Reply With Quote
Really messy solution with dual circuit brakes as you either need a double ended servo or two separate servos.
Better just to use a more suitable master cylinder ie one with a smaller bore designed to work without a servo.
posted on 24/2/10 at 02:34 PM Reply With Quote
The OP would need two of those.
NS Dev
posted on 24/2/10 at 03:14 PM Reply With Quote
other option (but totally ott and excessive for a locost type vehicle) is an electrically boosted setup, rob from an old Jag XJ6
doddy
posted on 24/2/10 at 05:03 PM Reply With Quote
for what reson do you not have room
i had to buy a floor mounted pedel box so i had room for my throttle bodies when i fitted a zetec
