Author: Subject: Another Weber DGV carb question!!!
posted on 29/4/04 at 12:07 PM Reply With Quote
A simple one this time...
When I took my carb off last night I found that I had an assortment of gaskets between it and the manifold - from the top:
1 thin black rubbery one
1 brown fibrous one
1 1cm thick rubber one
1 brown fibrous one
1 brown fibrous one
This seems excessive!
Assuming that the thick rubber ones are for heat & vibration isolation, shouldn't I just have:
1 brown fibrous one
1 brown fibrous one
The Haynes book of lies doesn't give any clues (it expects you to put back or replace whatever you just took off, I guess).
rgds,
TL
posted on 29/4/04 at 12:19 PM Reply With Quote
I agree with you, a bit excessive.
As it happens, I need a "thick rubbery one" for my DGAS, but it needs to have 2
separate choke holes (about 41mm dia),
and not one big oval hole. If you have a spare which fits my description, I'll send some beer tokens if you like.
Terry
posted on 29/4/04 at 12:21 PM Reply With Quote
Mine are the 'big oval hole' type* - sorry!
* like a girl I once knew
TL
posted on 29/4/04 at 12:24 PM Reply With Quote
Thanks anyway, David
p.s. 2 x 41mm dia. holes: Like a girl I once knew!
[Edited on 29/4/04 by TL]
Terry
Surrey Dave
posted on 29/4/04 at 12:36 PM Reply With Quote
Sounds right , I've only got the thick fibre spacer and 2 gaskets on my DGV
