Nash
| posted on 2/3/10 at 09:41 AM |
1300 x-flow ignition timing
Hi all
anyone know what the ignition timing on the above should be set to please?
Thanks............ Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
GaryM
| posted on 2/3/10 at 11:26 AM |
Initial static advance?
Mr. Haynes says either:
1.3 LC and LC Economy (from Nov 1977) 12 degrees BTDC
1.3 HC and HC Economy (from 1977) 10 degrees BTDC
1.3 (all other versions) 6 degrees BTDC
Nash
| posted on 2/3/10 at 11:34 AM |
thanks Gary.
I trust you and the family are well?
.....................Neil
procomp
| posted on 2/3/10 at 12:46 PM |
Hi
The Haynes manual dos not take into consideration that there are different Dizzy's available or that the bob weights and the advance curves are
wildly different from one dizzy to an other.
38 deg max at 5 k revs.Will be right in the ball park for best performance.
Cheers Matt
| posted on 2/3/10 at 01:30 PM |
Also if the engine is reluctant to hot start due the ignition being too advanced at cranking speed you may have to give the static timing less
advance.
If the engine is on points ignition the contact breaker gap is hyper critical especially with the Ford's own Fomoco (aka Autolite) distributor
--- the points gap for the Fomoco distributor is 0.023" to 0.027" with new points always set at the wide end, put the tiniest
possible drop of gearse on the cam and recheck the gap after 15 minutes running.
