MakeEverything
| posted on 3/3/10 at 09:51 PM |
V6 Flywheel PCD?
Does anyone know what the PCD of the cologne V6 manual flywheel is please? The renault one is approximately 75mm, but i want to know if i need to fit
the renault flywheel or the ford one. This will also dictate which starter i use.
Kindest Regards,
Richard.
Dingz
| posted on 3/3/10 at 09:58 PM |
Richard I think you will find that you need to use the cologne flywheel, possibly lighten it a bit. How are you connecting the gearbox to the engine?
went on and on.
MakeEverything
| posted on 3/3/10 at 10:13 PM |
Using two 5mm adapter plates, with tabs to bolt together and hold the gearbox to the engine.
Kindest Regards,
Richard.
turbodisplay
| posted on 4/3/10 at 07:40 AM |
The 2.9 flywheel is thicker than the 2.8 by a good few mm.
If you use a 2.9 flywheel i think you will have the cluch in a good posistion.
Pcd of flywheel bolts is 45mm by my measurements.
Darren
MakeEverything
| posted on 4/3/10 at 08:58 PM |
Darren
Cool, Thanks Darren. I didnt remember the 2.8/2.9 being as big as the renault. As above, i think the 2.9 is what im after.
Do you have one for sale?
Kindest Regards,
Richard.
