Author: Subject: Zetec blacktop oil pressure sender
norfolkluego
posted on 8/3/10 at 07:43 PM Reply With Quote
Where is it? The only thing I can find that might be it is just under the inlet manifold but that had the wire cut flush so I'm hoping that's not it
lotusmadandy
posted on 8/3/10 at 07:50 PM Reply With Quote
It's under the inlet manifold just behind the oil filter.it should have a terminal on the end of the sender
Sounds like you could be looking at the knock sensor,that has a stud coming through the middle with a nut holding it on (if that makes any sense)
[Edited on 8/3/10 by lotusmadandy]
snakebelly
posted on 8/3/10 at 08:16 PM Reply With Quote
think you will find its usually to the left of the oil pump / filter when looking at the inlet side of the block. the sensor with the cut wire is as already stated a knock sensor, although i have also heard it described as a cylinder head temp sender, either way its surplus to requirements
