Author: Subject: lengthen a de dion axle
femster87
posted on 11/3/10 at 07:34 PM Reply With Quote
am after a de dion axle, just wanted to know if you could lengthen one before i buy one. i noticed the most common ones are the gts ones
Ben_Copeland
posted on 11/3/10 at 07:38 PM Reply With Quote
First question is.. Why do you need to lengthen it?
Ben
Locost Map on Google Maps
Enter Your Details Here
SPYDER
posted on 11/3/10 at 07:44 PM Reply With Quote
If it's only a small increase that you are looking for it would be a lot easier to use different offset wheels.
Actually lengthening the axle tube would necessitate longer driveshafts too.
Geoff
femster87
posted on 11/3/10 at 07:47 PM Reply With Quote
got a wider chassis, a +442
Ben_Copeland
posted on 11/3/10 at 07:48 PM Reply With Quote
SO you going to lengthen the drive shafts too???
Ben
Ben_Copeland
posted on 11/3/10 at 07:56 PM Reply With Quote
As far as i'm aware, the +442 use sierra track, so no need to lengthen?
Ben
t16turbotone
posted on 11/3/10 at 08:15 PM Reply With Quote
The +442 is a wide chassis which is same track as sierra. I brought a 'wide' GTS de dion axle, it uses standard length sierra drive shafts. The standard (narrow)GTS de dion axle needs the drive shafts shortened...
femster87
posted on 11/3/10 at 10:28 PM Reply With Quote
thanks
