Author: Subject: re routing the lower steering column...(VAUX)
westy turbo
posted on 11/3/10 at 10:22 PM Reply With Quote
Being LHD on a vaux turbo engine is causing so trouble .... the turbo is in the way of the lower steering column...any one had an issue before in a same set up,or in a different one?
austin man
posted on 11/3/10 at 10:25 PM Reply With Quote
silvertop zetecs in MK Indy's cause a problem, fitting another UJ gets around the column hitting the oil filter, I have a couple of pics in the archive
westy turbo
posted on 11/3/10 at 10:28 PM Reply With Quote
re
cheers!
westy turbo
posted on 12/3/10 at 10:09 AM Reply With Quote
any more help,will be more than apreciated
