Author: Subject: Megajolt - Runtime error - Microsoft isual C ++ Runtime Library
rich201283
posted on 12/3/10 at 05:59 AM Reply With Quote
I connected upto the megajot configurator ok.
I ran the hypertermial command Via C and pressed S got no responce.
Now whenever i try to connect to the megajot configurator i get an error.
Does the firmware need re-flashing?
Runtime Error!
Program: ...les\Megajolt Lite Jr. Configurator v4.0.2\mjljConfig.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
mediabloke
posted on 12/3/10 at 12:42 PM Reply With Quote
Program: ...lesMegajolt Lite Jr. Configurator v4.0.2mjljConfig.exe
Do you know if the MJ hardware is V3 or V4? The configurator software is version-specific: V3.x for V3 hardware, V4.x for V4 hardware. They're physically different too: V4 has surface-mounted components, IIRC.
rich201283
posted on 12/3/10 at 01:17 PM Reply With Quote
Hi it is V4
The config software did work until i tried hyper terminal, i pressed C got no responce, then pressed S got no responce.
I then tried to re- connect to the config software where i get the error.
Im woundering if i started some sort of runtime process on the chip when i pressed C or S
I was going to try an flash the chip but i get an error when i try to run the dos command, Em: this is not a valid win32 application
[Edited on 12/3/10 by rich201283]
MikeR
posted on 12/3/10 at 01:23 PM Reply With Quote
first message
re-download the app and install it.
The application sounds like its trying to do something but its failing to do it. This is either cause their is a bug in the megajolt software or part of the XP / Vista / Win7 machines hasn't got the required instructions (the library is out of date). I've no idea what libraries are missing but running microsofts windows updater tool may help.
second message
you're trying to tell the computer to run something, but the thing you're telling it to run isn't a program.
Check the command you're typing in / re-download the application in case it was corrupted on download.
rich201283
posted on 12/3/10 at 01:54 PM Reply With Quote
I have already tried downloading the software again, Ive also tried another laptop, Can any one advise how to re-flash the firmware as i get an error when i try - Im pretty sure the its the processor chip software thats causing the issue
mediabloke
posted on 12/3/10 at 11:30 PM Reply With Quote
Saw your query on Brent's forum. Did that sort it?
Francis
