FASTdan
| posted on 12/3/10 at 12:51 PM |
Remote filter heads?
There's nothing special about the remote filter heads you buy is there? Ie internal valves or anything?
Reason I ask is I am planning to utilise a slightly modded remote filter take-off plate that I already have - which basically just has in/out ports.
Any particular orientation it needs to be mounted? I wouldnt expect so but thought it was worth checking....
flak monkey
| posted on 12/3/10 at 12:53 PM |
Fit with filter hanging down or horizontal otherwise oil will drain back from filter.
Other than that, nothing to worry about really.
Sera
http://www.motosera.com
| posted on 12/3/10 at 01:31 PM |
hanging downwards is best - most fileter have anti-drain valve - a flap of plastic behind some holes, simnple but effect but they will drain to some
extent via the central hole.
choose the remote filter wisely as regards to the thread - most (from mmeory) are 5/8 UNF (?) and here is a plethora of filters that will fit - big
uns - long and large diameter like Range Rover, medium diameter and long like golf, medium short like Ford corssflow and even shorter ones.
a trip to halfords looking in the oil filter boxes will leave you astounded by the choice avaialble.
