Author: Subject: 1600 x flow rebuild or sell in bits
kelloggs
posted on 16/3/10 at 08:07 AM Reply With Quote
I am in a bit of a quandray do I rebuild or sell in bits, 1600 x flow engine sheared a bolt on the crank, luckily it was only at ticxkover and didn't do to much damage, crank requires re-grind, also new con rod, main bearings & big ends. Can rebuild to complete engine with all bits fitted & ready to run. Photos in Photo Archive
posted on 16/3/10 at 11:02 AM Reply With Quote
depends on monye and time?
your signature says you are fitting Zetec - so presumably you are asking if it is worht fixing up the crossflowe prior to selling?
find out how much it will cost to fix it - cran regring, new shells, rod - s/h and figure how much you'd get for the eingine (£ 50 to £ 300 top, latter for a tuned runner) plus the time to do all that.
posted on 16/3/10 at 07:12 PM Reply With Quote
Which bolt sheared, big end or flywheel?
Problem with the xflow is they aren't especially cheap to rebuild these days but also a damaged one in bits isn't worth a lot (unless it has a decent big valve head?)
[Edited on 16/3/10 by MikeRJ]
