Author: Subject: Rover v8 injection plenum gaskets
NS Dev
posted on 17/3/10 at 01:44 PM Reply With Quote
Anybody know where I can get the gasket that goes between the inlet manifold and the bottom half of the inlet plenum on a rover v8 with std injection (its a 4.6 but on std 3.9 plenum and remapped lucas injection)
I got one and its for the later gems manifold, can't find the earlier type....
Agriv8
posted on 17/3/10 at 02:03 PM Reply With Quote
dont think there is one - I have never seen one and gone through 3 or 4 plunms.
I ussually bolt together with a skim of bathroom sealant and wipe anny excess of the inner ports.
regards
Agriv8
NS Dev
posted on 17/3/10 at 02:08 PM Reply With Quote
aha! that would be why I can't find anybody selling one then!!
cheers
wanted to check before I did the same as you!
next, having never mucked about with rover v8's before, is there any trick to installing the dizzy, or is it just line up a pickup tooth (electronic dizzy) when crank is at tdc and then put the leads on in the right order round from there......I assume so!?
boggle
posted on 17/3/10 at 02:41 PM Reply With Quote
the dizzy runs off the oil pump....
make sure you prime the oil pump if its a rebuild....
i didnt and it caused me weeks of head scratching.....
u2u me for details
Agriv8
posted on 17/3/10 at 03:46 PM Reply With Quote
cheers
one of the all time best jobs of a rover v8.
the fun bit is that as stated - the dizzie has a key to drive the oil pump so you need to get it timmed close enough. then turn the engie over to engage into the pump. then accuratly time it up.
I Have the rover PDF on how to do it somwhere I can email it over if required
Check as it is very eay to get it 180 deg out got the tee -shirt on that one!!
Regards
Agriv8
edit to add tdc marks on RV8 can be 6 deg out on the worst engines - I usually check with a socket extension bar down throught the spark plug hole onto the top of No1
edit 2 2 pages in PDF sat on my destop U2u email address and I will email through
[Edited on 17/3/10 by Agriv8]
