flak monkey
| posted on 27/3/10 at 08:49 AM |
Floor mounted pedal return spring?
Anyone got any photos of floor mounted pedals with return springs? My throttle pedal could do with a helping hand to return!
TIA,
Sera
http://www.motosera.com
speedystew
| posted on 27/3/10 at 09:13 AM |
did you have same problem with your roller tb's,could be the return springs on your raceline set up,have a chat with chris about stronger
springs on the throttle linkage .you could just pop a spring from the bulkhead to the pedal between the pivot point and the cable to pull it
back,just make sure the problems not with the throttle linkage/cable route or you could end up with an engine revving it's nuts off on a closed
throttle pedal with a loop of inner cable in the foot well
