FrankP
| posted on 28/3/10 at 06:29 PM |
Oil catch Tank Query
I have seen 2 types of caych tank to connect up to the breathers on my zetec engine.
One seems to have a a filter and one connection.
The other seems to haver to pipes which seems to imply that it can take 2 connections one from the sump and one from the rocker cover?
Which is the tank to get and how should they be set up?
Being breathers I am assuimng that they need the ability to breath? So you need to have an outlet to the atmosphere?
Any help or guidance welcome.
Frank
| posted on 28/3/10 at 06:35 PM |
Mine just run to air....
Does your engine have the breather pipe thats attached to the back of the block?
Run a pipe from the block breather (under the exhaust manifold round the back of the block, T it into the cam cover breather and run it wherever your
conscience allows.
OEM is for the breathers to go into the inlet to recycle.
