| posted on 28/3/10 at 09:04 PM |
could this be why?
those of you who are paying attention will recall my last drive resulted in a ride on the back of receovery truck due to over heated engine.
well, finally I got the head back and fitted it all together.
for fun, ok, not that much fun. I thought I'd see if the brand new thermostat opens in a pan of boiuling water.
guess what? it did not. so I compared it to the old one I replaced and gues what, that one did, about 90 degree C.
hmmmm, how likely is it that this was what caused my engine to overheat?
I did drill a 4 mm hole in it but surely there would have not been enough water flow so the car would not have made a journey of any distance with a
closed thermostat?
most strange. (and bloody expensive).
prawnabie
| posted on 28/3/10 at 09:08 PM |
If it opened at 90 degrees in a pan of boiling water, it would have opened at 90 degrees in the car? I run my crossflow hotter than that and its been
in the car for 18 months and done 600 miles like it with no problems.
| posted on 28/3/10 at 09:16 PM |
yes it would - that was what the old thermostat did , the one I junked (well put in a box actually).
the new one remained closed even in boiling water, then I just held it in the flame for a bit and still not opening.
prawnabie
| posted on 28/3/10 at 09:21 PM |
Ah right when you said new one I assumed it was new not been fitted.
Yes your right when a company can hash up a £4 part and it ends up toasting an engine it can be annoying lol
prawnabie
MakeEverything
| posted on 28/3/10 at 10:06 PM |
Why did you drill a 4mm hole in it?
Kindest Regards,
Richard.
prawnabie
| posted on 28/3/10 at 10:09 PM |
It acts as a second bypass to stop the front half of the head overheating. Also aids bleeding the sytem.
MakeEverything
| posted on 28/3/10 at 10:58 PM |
4mm isnt very big!?!?
Kindest Regards,
Richard.
jollygreengiant
| posted on 28/3/10 at 11:03 PM |
Doesn't need to be big just needs to let air through. All the 4mm hole needs to be is at the top of the of the thermostat area.
Bluemoon
| posted on 29/3/10 at 11:17 AM |
Used ~2mm in mine, not by pass though. I have all-ways checked the thermo before fitting (it's quick to do, and if it fails consequences are not
good) in case it's a dud, I guess if I used OEM ford bits I would not bother checking...
Dan
